Is there any difference or improvement between the New and Old style Ada heads for 61x besides appearance?
Also, are the 61x and 62t shells the same?
They are basically the same design. All yamaha head shells are the same for 701 61x and 62t as well as 760 62t. The only difference is the dome sizes. The ADA big bore head shell is for BB850s with big sleeves and use Sea Doo domes.
As the buzzard said, ADA heads and domes can wear out usually from undertorquing and the shell gets loose enough for domes to wear into bottom of head shell. But most ADA heads can and do last a long, long time without issue.
If buying used, check the bottom of head shell and top of dome for wear.
(Worn ones can be used again with some 'redneck engineering' using beer can for shimming.
Also watch out for the fake ADA heads floating around. If you buy new, then choose an authorized ADA dealer and avoid ebay and pwctoday. If buying used, check it out well by comparing to info here:
http://www.x-h2o.com/index.php?thre...feit-ada-head-being-produced-and-sold.108163/
http://www.x-h2o.com/index.php?threads/another-fake-ada-head.118426/
