- Santa Cruz CA
I have a 1993 kawasaki 750 sx that i have lost spark on. It was running great then done. I do happen to get a spark when i let off the start button. I was thinking the switch was grounding out. I have pulled the start/stop switch apart and cleaned everything. I tested all the wires for continuity. Everything checks out ok. I checked all my wires into and inside the e box. tested for spark with the stop switch apart.
The stator ohm readings check out.
Im really confused on whats happening. Do I possibly have something grounding out? Has anyone come across this issue before?
Keith
Keith
