SX/SXi/SXi Pro No start 750sx
Salem, OR
Okay, I just got done doing an oil injection block off and a new impeller along with an intake grate. I just finished today and I go to crank it over with fresh premix and now it won't turn over. It just clicks. I put the charger on the battery and it says it is charging but all my ski does is "click" everytime I push the button (very annoying) I took the starter wire and put it directly on the battery hot wire and it didn't do anything.
I had the ski tipped to the side for about 2 weeks and the oil 'oozed' out. I was thinking maybe the battery acid also 'oozed' out???
Anyway, I'm trying to go to the lake tomorrow...any help is appreciated! Thanks:wave:
Salem, OR
Okay, I just changed the battery for a new one...and still a no-go. I then hooked the battery to the positive wire to the starter and the negative to the ground and nothing. I stuck a screw driver to jump the solenoid and nothing happens. Does this mean my starter is bad? I already took it off...i'm just waiting so I know what to do???
Thanks
JetPilot1970
Work at Sea-Doo Factory !
Quebec, Canada
Did you have remove the engine to install the block off plate ? I suppose not.
Remove the 2 spark plugs and try to start. This may help to find if the energy is too low to crank with compression. Take a look in the spark holes and try to see if the cylinders are ok. If it still doesn't start then your problem may be...
1) Electric: the solenoid may be stuck.
or
2) The engine is stuck: Try to push the pistons with a long screwdriver in the spark plug holes. The piston have to go down in the cylinders with a medium force.
We just try to find where begin the problem, now you know if it's "Before" the engine. I mean between the battery and the starter or after it... The engine itself.
Let us know the results, for the community informations.
S. Robi
Quebec, Canada
i got the same problem right now with a 750 sx i am putting back together. you hit the button and the solenoid just clicks. i put the working starter and battery out of my sxi pro in and still the saem thing. this leads me to believe the solenoid is junk. will let ya kno if i get it working and what i have to do.
Salem, OR
I took the starter apart and I couldn't get the brushes to go back. Unfortunately I don't have 10 fingers on each hand. I'm thinking about just parting it out...
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
they got NEW china made starters on fleabay for about $75 shipped.
just get on of those and get wet !!!
good luck
gorilla
