Super Jet Not charging- Regulator or Lighting Coil? (measurements incl)
swapmeet
Brotastic
Arlington TX
Ok,
I did a little searching, and what i'm coming up with isn't adding up so here I am, being a knuckle head starting a new thread.
Here's what i've found.
AC voltage across the two green wires off the lighting coil. It bounced around all over the place 12, 14, 7, 16, etc. That was at idle
DC voltage at Battery while running did the same thing. 6, 14, 3, 20+ (meter was set at 20v and under). @ idle.
Resistance from Green wire from regulator to ground: Greater than 20M Ohms.
Resistance across positive and negative battery cable: Greater than 20M Ohms.
Does this mean anything to anyone? There is a chance my meter isn't playing nice, its old but i feel like what i'm presenting is accurate. If it sounds unaccurate, tell me and i'll get a new meter and try again.
Thanks in advance!
