Dre0256
BORICUA
- Jetskicave, MD
Just got done building my son's B1, 701 Riva red pipe, Riva girdle head (35cc domes), wetjet 46mm carb/intake, a/m water box (triton I think). Ok compression 185 psi, fire fuel all good. Took out to water test, kept on cutting off. Replaced check valve on tank and put new plugs. Ran better but kept on cutting off to the point where it would not start. Took home checked over, front plug was loose and lost compression in the front cylinder down to 40 psi. So two problems obvious loos of compression and keeps cutting out like its running out of fuel. When it would shut off, it would start right back up until it did not any more. Would the loose plug cause it to run lean? Thanks for any help.
Dre
Dre
