- Tidewater, VA
Let me preface this with the fact that in my other life I was an electronics tech. I am a pain in the ass about detail and I know this.
My OCD kit is outstanding. The wires, connections and shrink tubes are high quality and done with a refreshing level of competence. The circuit is wired such that both pumps will turn on in either switch position. However, if you want a different config the connector is already there for you to do it. The chafe guards are appropriate and additional guards are supplied for the pump wires. The ebox block off is spot on. There is no Sanford and son bullpoop here. Block offs, extra shrink. OCD for realz. The fact that Chris (JetManiac) carries this stuff should have been more of an indicator to me that it would be top shelf merch.
The only thing I might have done differently might have been to use hot glue style heat shrink. But that could be overkill and there is no serviceability with that solution.
Spend the 55 bucks and RTFM. You will not be sorry.
Peace.
Peace.
