Blaster Ocean Pro Nozzle
I recently got an Ocean Pro nozzle for my blaster. I was looking for something to do quick steer a little cleaner than cutting material out of the stock nozzle. It turned out that the bolt holes where conveniently ob-longed really bad so I just took it to a machine shop to be fixed. My question is has any one ever ran one? Is it good. It has that weird square shape so I wasn't sure if its an improvement or not. I drilled and tapped it closer to the nozzle for the cable to do quick steer and also drilled and tapped my stock stem under the hood to move it to the outside. Just wondering if this nozzle is going to be worth the effort.
tshank123
Yo hablo ingles
Vegas
I've ran one for a couple years now, race application. I'm not sure if its better than any other extended nozzle but I like it. You'll want to run a blaster 2 steering cable, the stock cable can't handle the extra force and will just bend.
tshank123
Yo hablo ingles
Vegas
The pump end is just fine but you have to adapt the other end if you want to run the B2 cable. There are some brackets you can buy or you can just make your own. I run the Tobtek bracket. Its nice, has a lot of adjustment. He sells the brackets on here.
