Other ODI Grip Installation
How do you rotate or position an ODI grip after you pushed it on?? I dont want to ruin my new kommand bars.
That things is stuck on there... Do you guys have some trick to install these things??
SterlingSilva
Colorado Springs
ODI grips with lock rings??
there are set screws on each lock ring. should turn freely with them loose.
If they are just regular full rubber slip on grips try shooting some air under the grip while turning it
CA
yup you will need to sand a bit, it will make your life much easier for putting them on and taking them off. The first time i put them on knurled bars i had to dremel the grips off....
Delaware
douse the screws and threaded ring portion with teflon thread sealer else you'll be cutting them off as alum and ss don't mix.
Lick your thumb and rub small circles, yes small circles, now reverse, north south east west, left right, clockwise, counter clockwise, forward backward, up down.
Should slide right on after that.
Vumad
Super Hero, with a cape!
St. Pete, FL
No no no. You are confused. That is the key stroke you need for full life on Grand Theft Auto 3.
Odi grip install is left, right, up, down, X, square, triangle, O, RB, LB.
Vumad not falling it for my Technique for ODI install has been working great for a long time.
We can all use a change every now and then. I will try it out !!!
