OEM F/A on aftermarket carbs
So i have searched high and low and can only find one company who sells adapters for running the oem flame arrestor intake assembly on aftermarket carbs. However its for the individual f/a's and i am looking to use my dual 44 setup. Putting them on black jacks but should be the same for all aftermrket carbs.
BrightE's
Paul
Seattle, WA
I have 3 Thrust Innovation adapters for big carbs. One is brand new, and the other two have a single season on them if you're interested
Sent from my LG-F350K using Tapatalk
Vumad
Super Hero, with a cape!
St. Pete, FL
If it's 44s, have you looked into the 760 airboxes? B2, XL760, GP760, etc run OEM 44s and the same style airbox as the superjet comes stock. I put a XL760 airbox on my 750X2 with dual 44mm mikunis. I opened op the outside of the throat bore about 0.5mm on each side with a sanding drum (bolt holes with a bit) to make up for the slightly different carb spacing. It could be slightly affecting my air curves but it does work very well and keeping the X2 dry is critical. @Philip Clemmons does bring up a very good point.
