? on 750 front exhaust.
I have been researching the dual exhuats option for my kaw 750. Running only front exhuast would I need the stock water box? I know about the noise and oil residue. Wondering about back pressure and taking in to much water into front exhaust. I am not a mechanic so is the exhaust pressure enough to keep water from entering front exhaust when sub, nose stab etc.. The superjet exhaust is split after the waterbox when using front exhaust. Not sure how to make exhaust work properly on kaw.
Waternut
Customizing addict
Macon, GA
Well I be curious to here more information on this since my side footholds are blocked by the exhaust coming out of the back.
I do know that the exhaust does have enough pressure coming out to prevent water from getting in when not moving. However, the trick to prevent doing something dumb, you'll want to make sure the exhaust is pointed straight to the side or angled backwards slightly so when you do a nose stab you don't flood the engine.
