Is it a hard thing to install????........................................srry if all of my posts are dumb questions but i am new and i appericiate all of your guys help!!!
its not an easy one...i havent done it but it would require that you remove the motor and whatnot...you basically just drill a hole through the firewall all the way out the back..the key is in sealing it up after you are done..im sure there are some threads about instaling it..
I did the home depot one way, and 90'ed it to exit into the pump area.
If your putting in foot holds, now is a good time do it if your going to 90 it. If your going to have it exit out the back, then I'm not really going to be that much help there.... as I kinda understand how to do it, but I found clearing out the foam to be easist for me (I did the 90)
