- Cleveland, Oh
I've had it with these dual pumps killing my battery. In Cleveland the waves are not spaced out enough to pump out. What are the best one way valves? Do the valves pull more volume than dual 500s?
We have very little space to recover and plan out a line on the great lakes...you can be separated from your ski immediately realizing its coming. If it were me I would look at your charging system and make sure there is no midshaft/pump area leak. I have left my bilge on for almost an hour on accident and the battery is still fine. This is a single 600gph. It's a deka battery
'm sure others will chime in. If you run total loss, run the bilge at will. Just my .02 fellas.
Yep. and this will do it for you! I have scupper and now just plug it up with a plumbing plug in surf. Best of both worlds. PS...I'll NEVER run a bilge switch
[video=vimeo;46853698]https://vimeo.com/46853698[/video]
(i meant with the ski off and sitting on the beach)
So did I....
