- Oregon
Can anyone tell me what would be a good starting point for the 3 header pipe screws when running a Parallel setup? I ask as on the blaster it looks like I have to remove everything to get to the bottom adjustment. Current water temps here are 57 degrees, in August we barely hit 71, this is a rec ski and I plan to do a few races. one being on a smaller pond.
I have what I believe to be a NYNJA pipe, while not as good and not the same as a TNT its similar I think. I read that Tim recommends running parallel cooling as with the water being cooler it requires less water in the pipe. His recommendation is the pipe runs best in race world hot and it needs to steam but not sizzle. Jr. just opened up my manifold from 42mm to I believe 48mm. I plan to put a T on the top outlet of the header pipe with one going overboard and the other going to the stinger with a 3mm restrictor.
