Super Jet Parts List
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Ok, I think this is complete now. Hardware is obviously not listed, there is a partial list for that here. I used ~ to designate sub components for certain parts. This list can easily be copied and pasted into excel or word for a variety of uses. Let me know if I need to make any additions or corrections.
Engine
Bendix
Carbs
Cooling Plumbing/Fittings
Coupler
Electric Box
Exhaust
Flame Arrestor
Flywheel
Flywheel Cover
Gaskets
Long Block
~Bedplates
~Cases
~Crank
~Crank Seals
~Cylinders
~Head
~Piston Kit
Intake Manifold
Reeds
Starter
Stator
Fuel
Fiilter
Pickup
Plumbing
Primer/Choke
Tank
Tank Straps
Vent
Hull
Battery Tray
Bow Eyes
Coupler Cover
Ex Hose, Long
Ex Outlet
Fuel Filler
Gas Tank Mounts
Hood
Hood Hooks
Hood Latch
Hood Seal
Hull
Midshaft
Motor Mounts
Pissers
Scupper
Turf
Waterbox Mounts
Misc
Battery
Battery Straps
Fire Ex
Fire Ex Holder
Waterbox
WB Straps
Optional
Air/Water Serperator
Bilge Outlet
Bilge Pump
Bilge Siphon
Bilge Switch
Dash
Flow Control Valve
Foot Holds
Foot Straps
Fuel Pump
Girdle Kit
Hand Holds
Hood Straps
Kenny Keepers
Limiting Rope
On/Off/Res Valve
Pole Shock Pad
Rail Bumpers/Turf
Sponsons
Tow Loops
Trim
Tubbies
Water Injection
Pump
Grate
Plate
Prop
Pump
~Driveshaft
~Pump Cone
~Pump Seal
~Reduction Nozzle
~Stator Section
~Steering Nozzle
~Wear Ring
Pump Shoe
Through Hull Fittings
Steering/Controls
Bars
Bracket/bolt
Chinpad
Grips
Lanyard
Nose Cover
Pole
Pole Spring
Start/Stop
Steering Cable
Steering Cable Hull Fitting
Steering System/Plate
Throttle Cable
Throttle Lever
OCD Solutions
Rentz, GA
Edited: pulled my list to keep things clean.
A good addition would be to list sources for the parts in the instances that they are available from other craft and model years.
