HollaHolla
FB Name: Jack Hoff
- Southern Maryland
My PFP pipe run dry is not flowing any water to the stinger and bottom pisser thus not into the waterbox.
Attempted troubleshooting has not been successful.
Any feedback appreciated before I licorice something up or learn the pipe is just licoriceed lol.
Extra Details:
-Running Dual cooling...Direct waterline to bottom of exhaust mani and 2nd waterline T'd to top of exhaust mani and then to pipes top water hose inlet.
-Pipe has run great for years and just started no water flow two weeks ago.
What I've done so far:
-Compressed air pressure through all lines.
-Engine still cools and pisses properly when being flushed but no water going to pipe.
-Water cooling line T'd to top of pipe provides water, BUT with less pressure I'd expect to see (don't have baseline on past pressure)
-Flushed pipe intake fitting (the top inlet right after exhaust mani) with garden hose pressure and after a few second the stinger and pisser started flowing water but has some noticeable back pressure until pipe starts letting water through to the stinger and pisser. (During this test I removed the filter and Flow Control Valve between the pipe to see what water was going through).
-Only thing I haven't done is reverse flush the pipe from the bottom pipe pisser and through the stinger water output fitting.
Extra Details:
