Zero Client
BeerrroooOOOT!!!
- Douglasville, GA
SO, I have an RCW Havoc hull which I like so don't flame me, but the Power Factor Pipe chamber will not rotate 'up' enough to reach anywhere near the PFP waterbox - as it hits the top side of the hull under the handpole bracket, and so I need to have a custom box manufactured for this ski. I started by taking measurements and jotting notes and lines down, and after about 3 re-draws I came up with the following design for building a waterbox based on the limited space of my hull.
My issue is, I don't feel confident that this waterbox will appropriately defend against water headed toward the engine, and I of course want to avoid hydrolocking the motor, or even the motor flooding when bobbing about in the surf, or even when sitting on a beach stand with the ass end in the water a bit.
It seems to me that this design may put the box too far below the waterline.
Can I do anything within the box to baffle or help prevent the rushing flows of water toward my expensive engine?
Any comments?
Any comments?
