PowerHouse Performance Engines, Now by LPW
Back in July, I had the need for PHP replacement parts. As many of you know, Zack has moved away from the PWC back into his prior business. Since then, the spare parts for his line of PHP motors has dwindled down to nothing. In my quest to source parts for my current need. The Opportunity to acquire the IP for Power House Performance was presented to me.
Over the years, Powerhouse has made a strong showing in the Performance Stand-up watercraft scene. Letting it slip away would be a shame. The motor line has a very loyal following. Rightly so, the motors simply Rock! I jumped at the opportunity.
I’m pleased to announce, all previous PHP motors replacement parts are now in stock at LPW. The only exception is the +4 & +10 crankshafts
Moving forward, The 3 main PHP motors will be updated slightly, putting my twist on how I like things done. Those motors are the Power Mouse, 898 +4 Billet, and 1015 +10 Billet.
Being that I now need to build these from scratch. My plan is as follows.
Build one of each. Test and tune each in my personal T1. Change up all carb, exhaust, ignition and Pump specs. So when a motor is sold, exact known tuning specs will be supplied with motor. No Guesswork! You hit the water running!
1st up will be the Power Mouse. The new name will be the LPW 780 Shredder +4. Currently 2 of these motors are in production. Testing will start very soon. After that, will come the 898 & 1015. Currently revising some details on each with the CNC shop. Then get into them.
LPW will continue to be your Best Choice for all LPW Motors, TPE Motors, DASA & XS Motors, as well as ET. I carry full line of Authentic TPE parts, Much of the DASA & XS parts. Plus authorized rebuild/repair for all. In house machine shop, for fast turn arounds. Solid attention to detail.
Paul Lehr
Owner / Tuner
Paul Lehr
Owner / Tuner
