Super Jet pinhole in case
tor*p*do
Squarenose FTW
NW NC
so I finished pulling apart my ported 701 and found
a pinhole from the inside to the flywheel area. :grumble:
can I epoxy it on the inside?
HELP!
Waternut
Customizing addict
Macon, GA
I JB welded the outside (inside the flywheel cover area) when I trashed my engine after a crank bearing let go. Never had a problem with it. You'll have to make sure that case is super clean if you expect it to stick though.
tor*p*do
Squarenose FTW
NW NC
cases we epoxied and ported and this is where the epoxy meets the aluminum.
is there anything better than jb weld?
2010brandingo
TEACH ME HOW TO DOUGIE!
ATL
jb weld is the shiz, but do make sure its clean. had a cracked block @18 inches long in my jeep due to a freeze and it is still holding up 2 years later. gotta love it!
SXIPro
JM781 Big Bore
JB Weld for the win. I've fixed more crap on my cars, boats, skis, and landscaping equipment with that stuff over the last 30 years than I can remember. There is always JB weld on my 'if all else fails' shelf in my basement.
