bondra131
Thaat's braptaastic!
- Coeur d'Alene, Idaho
Put a new New b pipe on my 2014 superjet and originally had changed NS springs to 95 gram but it ran rich on bottom and my pipe barely got warm so I figured the bottom screw (only screw that was open) could use a little tightening. I shut the screw then opened it 1/4 turn at most, maybe less and went for a test ride with the new configuration with stock springs in the carbs. This cleaned up my bottom end and ski felt great but I was running it wide open for a while and felt the motor starting to sieze 3 different times so I pulled onto a beach and found my pipe to be way too hot. Sizzled the water on anywhere water was dropped on the chamber from coupler to stinger nearly burnt the water lol so I take that bottom screw on the head pipe needs to be opened a bit more... Question is, is my brand new motor ok? 3 times a piston swelled enough to make the ski shut off. I suppose time will tell And I shouldnt be surprised if a piston breaks into pieces soon Huh?
