Custom/Hybrid pipe options for fs1
ok guys i have an fs1...right now im running a b pipe....im wondering what other pipes are out there that will fit...kind of looking for a dry pipe...thanks
JGringo
When in doubt, Throttle-out.
Answer:
**Stock to limited engine: B-Pipe
**Limited with porting: B-Pipe or Dry Pipe
**Big-Bore with porting: B-Pipe with stinger Mod, Dry Pipe, or Power Factor Pipe
You will be able to find a used dry pipe for cheaper than a used B-Pipe, and the likelihood you find a PFP pipe for any sort of deal is grim...
Depending on freestyle or race, as well as wallet size:
------>Dry pipe will have repeated weld-holding problems if you beat on it in freestyle/free-ride and is prone to a peaky (high RPM) power band.
------>B-Pipe is intended to be reliable and low-RPM based Power Band
------>PFP is intended to let your monster engines breathe while providing a wider potential power-band not possible with other exhaust systems
well right now i have a bpipe.....im looking for a dry pipe...i dont want to run a pfp cause i dont want to loose my full size tank...thats why i was wondering what pipes will fit...like a type 4 or 9....possibly a r&d....i dont want to have to rubbing problems in the hull or hood clearance issues....
JGringo
Ohhh... Gotcha. This is a problem I feel like you will need to talk to Rickter for, or you could contact Factory Pipe and see if they had anyone previously buy one for this hull...
Sorry, Hopefully someone else will chime in because I have no clue what will fit for you.
-Gringo
