leedesigns148
XXX 2
- Michigan
Can a Pipe be made out of fiberglass? I have seen them made with carbon fiber but I was wondering if they could be made of fiberglass.
Haven't you ever heard of the term "heat is horsepower"?
Keeping the heat inside the exhaust chamber will increase the sonic wave reflection and will make the pipe perform better.
The chrome ceramic coating should last forever and it won't turn that ugly dark grey color like the chrome powder coatings.
Snowxr hit the nail on the head about a fiberglass chamber. Carbon would be the way to go if you want composite.
I'm a smartie! :silly:
It takes about $400 of carbon to get an 8mm thick chamber. What do you think they are selling? A composite pipe must be round with no flat spots in order to work well and save weight. A sheet metal dry pipe is by far the best power adder there is for the weight and price.aren't the carbon chambers just fibreglass(about 8mm thick) with a layer of carbon on top to make them look nice?
the outside dimensions are the same but a lot of volume is lost inside the chamber because of the thick walls.
just saying what i've seen.........it wasn't HBC BTW.i highly doubt HBC is half assing carbon pipes.
