SX/SXi/SXi Pro Pipe question...
How many of you are running the Factory pipe with the R and D timing advance.... I read on Factorys site that your not supposed to.... or its not recommened. Whatever. Any body have any issues...
snowxr
V watch your daughters V
Waterford, MI
My 98 sxi pro had a factory ltd pipe with MSD enhancer and a r&d timing advance. It ripped. I purchased it set up that way, and never had a problem with it.
dfw
It is easy to melt pistons with pump gas and an ignition advance plate. Its a great mod as long as you never hold it WFO for more than a few seconds. People who get away with it are jetted rich of peak.
only recommend the retard module when using ignition enhancer and timining plate, and only needed when running WOT runs! not needed if you ride surf! I got a retard module if anybody needs one!
