Yea the pics kinda suck. No matter what lighting I try . They keep coming out poopty.
Just a reflection off the cylinder . Absolutely nothing wrong with the pistons
oh good.
Well, in my unprofessional opinion your wash looks a little lean to me. I like to see the "clean fingers" from the transfer ports to be a little larger than yours.
I like black/ brown on the crown, with the "clean finger" extending about 1/3 to 1/2 way to the middle of the piston. The fingers are clean, due to high velocity fuel/air being shot over the piston, cleans the carbon off.
And I use plugs. Black oily = probably let it idle after your wide open run. but since this is a big 1100, you dont really get a ton of wide open on it.
black non-oily = running well but has some responsiveness/power on the table.
chocolate syrup brown on ceramic electrode and ground electrode = pretty good, a TINY bit of power left on the table
light brown ceramic / ground electrode = nearly optimal, but i dont run them this close, cuz im a bitch and dont like buying new pistons/top end if anything goes wrong
light brown ceramic / grey-white electrode = lean, will start eating a lil aluminum off the top of the piston.
gray white everywhere = boom boom holes deto, preignition time.
110 for me, I run purple VP 110 leaded, and the chocolate syrup brown plug has a bit, to a lot of an orange tinge to it, when running straight 110. may not be noticeable with 20% 110 mix.
