Plug Question
no, stock head uses HS
the ES will get whacked by the piston as it comes up:smashfreakB:
I believe the ES plugs are too long, but not long enough to protrude through the dome into the piston crown.
I might be wrong.
From what I remember with an SXR - SJ plug mixup, it even runs, but not very well.
Actually, the motor with the longer-than-required plugs ran a whole lot better than the motor with the shorter-than-required plugs.
D-Roc
I forgot!
i got a motor from.... a guy and he put the hs plugs in the ada head. i ran it for at least a month until i decided to replace the plugs. it was like finding free hp. duh!
keefer
T1
Tennessee
Prolly lose a cc or two by putting the short plugs in the AM head. I ran across a guy running short plugs in an AM head the other day, we replaced them with the long reach ES units and he said it ran better.
