Pole breather tubes/pole bolt
Sanoman
AbouttoKrash
NE Tenn
You basically have to use some force to get past the bolt.Maybe try some (not a lot) heat on the tubes to soften them up.Then start shoving :)
JMew03
The call me Mew Mew
DFW,TX
Take the bolt out. Put tubes in. Put bolt back in. Use a flat head screw driver to move tubes out of the way to put bolt through.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Yami-Rider
TigerCraft FV-PRO
Texoma
I run a stock spring and dual breathers. That makes it even more challenging, but can still be done. Screw driver and some patients.
eastcoastjumper
James
Long Island
It's difficult. I have someone hold the pole up and help out. Make sure your breather tubes are adjusted so they fit around the bolt.
