- Cairns Australia
i have a freshly rebuilt 701 superjet motor, 82mm bore, riva red pipe,msd enhancer, k&n filters, ports mildly cleaned up, stock 38 mikunis, 75/135 jets. 1.5 needle &seats with 95gm springs. 1st ride out, won't rev past about 3500-4000rpm. At anything over 1/3 to 1/2 throttle it just dies, i confirmed it on the trailer.starts well & idles nicely. I checked the pop off pressures and both measured about 42-45psi. I've seen most people run 2 mm n/s with 95g springs which should give me 25-30psi (from memory) according to the mikuni chart. I swapped through all of my spare springs and got my pop off pressure down to 27-28 psi but havent been back on the water yet. Any thoughts on what pop off pressures I should be aiming for with 1.5mm n/s. Am I going the right way here or do I need to run 2mm n/s with the 95g springs.
