- Windsor, Ontario
Ok, so I'll start with yes, I've read basically every single carb tuning manual (Mikuni, Group K, Watcon, etc) like 10 times over, so I understand very well what pop-off is, how to adjust it, and have good idea of what my pop-off should be. However, my concern is that 99% of the resources I've found do not talk about "how" the pop-off should react. I've read multiple different opinions from "a clean pop-off dropping no more than a few psi" to "dropping 10-20 psi is ok" and even some people that say "its OK if it leaks slowly down to a hold point".
So, in an ideal situation if I was setting my pop-off to 36psi, what should happen once the needle pops at 36? Right now, one of my carbs is cleanly popping and re-seating at about 30 psi very consistently; while the other is popping more aggressively and re-seats cleanly between 14-18 psi.
