Hey everyone,
Just in the process of rebuilding the carbs on a "new to me" superjet with dual 38s.
I pressure tested the popoff and I'm getting about 38psi on my gauge with the stock 115gram springs (at least they look like 115g according to other posts on here)
I purchased some 80gram springs and put them in and tested the popoff and my gauge reads consistently around 22-24 psi.
I know that calibrations of different gauges can be off, but these readings seem a little low to be at least based on the charts I've seen on here.
I'm curious if anyone else has noticed this?
When I put the carbs back together later today, should I stick with the 115's popping off at "38" psi or should I give the 80 gram "22psi" a go.
This is a new to me ski with a brand new stock sbt motor dropped in, only ran it for a few minutes with the previous owners carb settings which were a disaster lol
