Octane Porous bondline?
VA
A couple of weeks ago I noticed that my ski was really heavy in the rear. So I figured it had to have water in the rear and couldn't figure out where it could be coming in at all. I went onto Watcon's site to check out the drain kit- http://www.watcon.com/Catalog_Pages/Oct_Hull_Drain.htm and it said the bondline can be porous. I let the water out Monday night, a good 3.5 to 4 gallons of water came out.
I was just wondering if anybody else has experienced this problem? I imagine it was building up in mine for a while now.
I've been draining mine between rides for a couple of years now. Most of the leakage on mine is around the tube tube where the driveshaft goes through the hull. Some day I may cut out the tray and re-seal and foam. For now I just drain between rides.
