Freestyle Porting lowers compression?
swapmeet
Brotastic
Arlington TX
Try to keep this short and sweet.
Have 61x, hammer ported by groupK.
Installed ProTec C2 head w/37cc domes.
They claim I should see 185psi.
I get 155&160.
Protec claims it's because of the porting.
Is this true? Can it change it that much?
Depends on Harry's porting specs, but yes - absolutely possible.
Raised exhaust ports lower compression.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
According to ada, you need 35cc domes to get 185 on a 701. 37 gets you 170. So that might be some of your difference. I would be more worried about the 5psi difference between holes tho.
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
also the larger the bore the lower compression, e.g I have 177 psi on 82.5mm bore with 35cc domes and I am going to install 33cc domes in that engine - should get about 190psi I guess..
You have that backwards. All things equal, a larger bore will have higher compression.
tor*p*do
Squarenose FTW
NW NC
my 61x w/35cc ada domes in a sharkfab head is spot on 185
if I dropped back to 37cc domes I would expect 170
Pretty radical freestyle ported cylinder
That 5 psi difference may be random. due a series of 10 comp tests each cyl
write them down and average to see if they are really that different
Waternut
Customizing addict
Macon, GA
5 psi different is nothing. Once you start seeing more than about 10% difference, then you should start considering a new top end or rings. Even then, I'd probably try to finish the season before tearing into it.
