Used power factor chamber. Purchased as a wet chamber and never ended up using it. $450
SmittySX Location Cleveland, Ohio May 10, 2019 #1 Used power factor chamber. Purchased as a wet chamber and never ended up using it. $450
sjetrider 615 Freeriders are addicted to T1 madness. Location in the 615 (Nashville) Jun 25, 2019 #7 so its cracked and running as a wet pipe or can it be run dry? If its not cracked I will take it.
SmittySX Location Cleveland, Ohio Jun 25, 2019 #8 sjetrider said: so its cracked and running as a wet pipe or can it be run dry? If its not cracked I will take it. Click to expand... Wet chamber only as described.
