Dry pipes are the way to go. More power everywhere. With some setup on water injection a dry pipe can't be beat. They are also 10x easier to install then a b pipe. At least the octane dry, type 4, powerfactor, and ask pipes are![]()
the original powerfactors were just that. a type 9 cut up. right now they are a little different then a type 9. if you can find a speedworx freestyle pipe that is a great pipe. are you running a stock 760 or a 62t based big bore?
engine builders recommend the b pipe because of simplicity and because it's what everybody does... this sport is about bandwagons. the b pipe is hype in my opinion. it works good, but far from a well performing exhaust. i ran a dry pipe on my octane for a season not once did i have a problem with couplers. had a problem with the b pipe once though.
prop selection, timing, and reduction nozzle play just as much on a b pipe. the difference is 95% of the people on this board use the b pipe so the setups are way more common and people share information on it more readily.
if you take the time to make sure your pipe is aligned properly the first time it will be trouble free. if you setup a crude water injection you'll have almost the same bottom with crap tons more mid and top.
