Used Powerfactor Pipe
Used Powerfactor Pipe Powdercoated Black. Chamber , Manifold in excellent condition, Chamber has been pressure tested and is not cracked. Waterbox has been welded at baffle plate as it had a crater crack at the end of the weld when i received it from Powerfactor and slowly got worse with every heat cycle. Manifold and Chamber have MX style spring setup that I added to keep chamber tight to manifold and preserve the life of the o ring. Manifold is tapped for H20 injection and EGT temp sensor. You get what you see in the pictures. 1350 or reasonable offer
