Hi guys,
I recently had a piston in my 701 go on me from running the engine too lean.
I had the cylinders bored to 82mm with Pro-x pistons and ported at the same time.
After putting the cylinders on, I tested the movement by turning the coupler by hand, and I noticed when each piston is at tdc and also at it's lowest point, I get a little pop kind of noise. I can get the noise to stop by putting some pressure on the tops of the pistons, so I thought it must be the little end bearings.
So, I order the bearing, install them and put the cylinders back on but the problem is that the noise is still there? I was under the timpression that there should be no noise at all when turning the motor over without the head on, apart from the obvious rings against the bore.
This gets interesting as I have a pretty much brand new Hotrods crank in the engine, which has done somewhere between 15-20 hours. I suspect that the big end bearings are the culprits, and presume that the engine is not safe to run in this state, can anyone confirm?
Where should I be looking to find out where the problems may have started? I'm not 100% on the big end bearings being the cause of the noise, but knowing my luck it will be.
Any help/advice would be great, as I don't, and probably shouldn't run the engine that way it is.
Thanks,
Leigh
Thanks,
Leigh
