Pressure test
SuperJETT
none
This is how I do a pressure test MacGuyver-style.
http://www.x-h2o.com/gallery/thumbnails.php?album=221
I had my exhaust blockoff plate that I made years ago, but not the rubber seal for it, and had nothing for the carb side.
So, off to Home Depot. The expandable pipe plugs didn't fit, the 1.5" was too small and the 2" was too big, so I searched and searched until I found vinyl stair treads, for $.99!
So I made seals for both intake and exhaust, used the bottom plate off the oem 44's for the intake side and my exhaust plate to hold them down.
Then I pressurized the block using my popoff gauge through one of the pulse fittings. This is not advisable if your reeds are in good shape, however my Boyesens don't seal very well so they will let the air through.
I pumped it up to 8psi and it was bleeding off very slowly, from my popoff gauge it appears based on the soapy water test. It was way less than 1 psi/minute which is what I go by, so I should be fine.
The reason I did this was because the last time I rode it seemed like the engine wanted to run away on the trailer, but only after revving some, and it did it once in the air while riding, but it only goes up to like 4000-5000 rpms maybe.
After verifying the engine is tight, I figure it's from my low screws being too far in plus running an upper 20's popoff. I put my low screws back to 1 turn and will test again today.
keefer
T1
Tennessee
My setup seems to be happy around 22psi pop off. Any lower and it dribbles fuel and loads up one cyl. Any higher and it gets a lean spot. Sounds like you are getting close to that ideal jetting point. Good luck
SuperJETT
none
you can also use the orange flat rubber gasket material from a hardware store.
That's what I used to have on the exhaust blockoff, but it has disappeared, and Home Depot didn't have any that I/one of their workers could find.
keefer
T1
Tennessee
Toby got us some adhesive backed rubber plate stock from a printing company that we cut out patterns and stuck two pieces together. We made several patterns, carb, exh. mani., and B pipe mani to header. We have used them many times and they work great! :biggthumpup:
SuperJETT
none
Better watch it, p-diddy will be selling those kits next week!
Actually, it's a great thing to sell maybe?
SuperJETT
none
Oops, he saw it already!
Hey, it would be a nice thing to sell honestly.
I think we're going to have to put together a X-H2o marketplace with all the little stuff that people sell grouped together in once place.
OUCH! Slamin me right in front of my face :Banane09:
