Jarrett1999
Vendor Account
What is the point of a primer I want to take mine off my ski but don't know if I need it's just ugly
If you install it on the return side, then there is no risk for air leaks messing with fuel supply.
Also to prime fuel lines with fuel on a yamaha, press and hold the stop button to kill spark and then press start to let fuel pump into lines. Let sit for a bit and vacuum will draw fuel through the lines. Do this several times before starting if initial startup after carb work or ona new build.
