Pro-Tec C2 girdled head hardware & o-rings
oxnard111
Creative RE Purchasing
anyone know the o-ring sizes for this head?
how about the length of the short studs that thread into the cases?
http://www.pro-tecperformance.com/c2andc3heads.htm
I bought a head that needs o-rings & studs. $30 for an o-ring set and $4 each for studs at Pro-tec. I'd like to order from McMaster if possible.
instead of using Pro-tec's stud/girdle nut/bolt system, could I use ADA studs with acorn nuts?
Don't have info for you, but I don't like the Protec girdle hardware. Don't like it that the there is a stud, a long nut, then another long bolt. I know people crack the RIVA style hardware, but its seems the easiest to work with.
I noticed the new Shark Fab head uses Riva style girdle hardware, but uses a long bolt instead of a top stud with nut.
I am considering ordering the shark fab, especially since he lowered the price another $20.
The Penguin
triple secret probation
I sent a PM to trls63 about his sharkfab girdle system. i just got the head today, so I'll mount it up on a spare case & cylinder so i can measure the lengths and go from there.
I don't care for the nut in the middle either. just another place for something to fail.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
order both O rings, from mcmaster carr.
-043, and -153
its ONE of those sizes ( almost all heads are one of those)
and its like $7 for 10 of them or something.
cheap enough to havesome spares, and some spares for buddies.
part numbers shortly..
no girdle hardware available from mcmaster carr as far as I know for ADA or shark fab heads.. I have both heads, ADA studs are too long for shark fab so they might work with your C2 head.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
9464K431
(Same as 9464K342)
Viton O-Ring AS568A Dash Number 043
In stock at $7.01 per Pack of 10
9464K114
(Same as 9464K342)
Viton O-Ring AS568A Dash Number 153
In stock at $2.75 per Pack
This product is sold in Packs of 2
( 153 is also sold in packs of 10 for $13.80)
8297T222
(Same as 8297T101)
Hard Viton O-Ring AS568A Dash Number 153
In stock at $13.80 per Pack
This product is sold in Packs of 10
The Penguin
those appear to be the o-rings to seal the domes to the cylinder - what about the 2 smaller ones that seal dome to head and the 2 that seal the head shell to the girdle and the head to the cylinder?
Mouthfulloflake
ISJWTA member #2
NW Arkansas
hmm, youll have to look up the ADA and Riva part numbers in the faq for those.
I cant recall them off the top of my head, I can tell you though, they arent viton, they are Buna-N so its like 100 for $3 on them.
same deal, buy a shiat ton of both, you WILL use them for stuff especially if you ride with other people.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
right, I thought you had some since you had tried them and they were longer.
girdled is NOT a cheap way to go, but its a good safe way to go, and it wont depreciate much it at all.
Ill check my O ring stock when I get a chance and verify my thoughts on the ada rings, and if ive got some 153 rings Ill send them your way.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
check this list, which of these sizes have you tried?
I bought the 50 or 100 qty of most of these so I can send you a handful if you have an idea which ones it might be.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
duh
ADA Hardware
ADA 701 O-Rings
701 Dome Base: #43
McMaster-Carr part # for Viton #43 o-rings is 9464K431
Buna:
Cord stock for outer seal 58" #9407K21
Dash 024 1 1/8" id #9452K78
Dash 020 7/8" id #9452K74
Dash 043 3 1/2" #9452K342
Riva O-rings
ADA 701 O-Rings
riva head oring sizes 701/760
Shell seal:1/16" Bulk Buna-N
From the top down:
Spark Plug:118 Buna
2nd :031 Buna
3rd :043 Buna
Compression chamber : 153 viton
The Penguin
I have an girdled ADA head on the shelf for another project - that's how I was able to try one of the girdle bolts and figure out it was too long. ADA gets $75 for the girdle kit and I'd bet $60 of that is the studs - at that price, I'll just get the short studs I need from Pro-tec
I also tried all the ADA o-rings - no luck there either.
so, I guess I'll just order the full o-ring kit from Pro-Tec tomorrow and try to measure them so I can order back-ups from McMaster.
