I've got a used Raider one coming for my freestyle Superjet. It (along with several others I notice) has the turn nozzle cut shorter. He is including the cut off piece so I can weld it back on.
Question: 1.) Why is everybody cutting the nozzle shorter?
If it's agreed that I should weld it back on, I'll probably need to machine the bore over the weld area at least. 2.) Do I keep it the same diameter as original or go with something larger. Or, it's just the turn nozzle and it doesn't really matter?
Thanks for the input!
