Super Jet Problems un SuperJet 650 (1993)
Buenas,
Haber si alguien del grupo pudiera ayudarme con un problema en mi SuperJet 650 del 93.
Al SuperJet se le cambiaron todas las juntas del motor nuevas para este verano, y el jet funciona correctamente.El problema viene cuando lo dejo aparcado en la playa (30 minutos) Cuando lo quiero volver a usar el jet no arranca y cuando quito las bujías a entrado un poco de agua en los cilindros.Alguien sabe que podría ser.
Gracias
Hello,
I was wondering if someone in the group could help me with a problem on my '93 SuperJet 650.
The SuperJet had all new engine gaskets replaced for this summer, and the jet works properly.The problem comes when I leave it parked on the beach (30 minutes) When I want to use it again the jet does not start and when I remove the spark plugs a little water has entered the cylinders.Does anyone know what could be.
Thanks
If fall then go take a break, burn the water out of the motor by riding hard for a few minutes. You dont wanna leave water in there for any length of time
