prop for my x2
Barrie, ON
Yes...I have one installed on mine along with a pump stuffer. You do have to machine it to set it back. Impros can do this or if you have access to the machinery you can do it yourself. I did mine at work.
shawn_NJ
Chasing waves.
Daytona Beach
You can run any of the standard 650 pump props from skat or solas, but they dont work as well as the SXR one.
8/16 (for a 650)
9/17
15 (for 650)
15.5
12/17 swirl (750)
ect.
betrezra
Eat, Drink, Breath x2's
I've tried a st 17, st 16, and st 16.5, and a 13-16, and a 14-21.
I got the most top end out of the st 17 on my wifes 780 x2 with port work. It ate the intake grate and nuked that prop.... so now it's got a 16.5 which works OK.
Impros is cutting a 13-18 SXR Prop for that ski along with a modified R&D pump stuffer :).... I'm hoping for extreme hook-up :)
My X2 is a 780 with twin 46's, blaster pipe, lw fw, is getting a magnum pump pressed into a 650 pump housing by Impros also. I'll be going from a st 16 which is what I have now, also tried a 14-21 which had NO bottom end, and a 13-16 which had not top end ;).......
Hoping the 13-18 Mag pump wil rock the lake.
Motorheads5
Livin the generation gap
ketchikan alaska
8/16 (for a 650)
9/17
15 (for 650)
15.5
12/17 swirl (750)
ect.
shawn what pitch was that sxr prop I got from you it is excellent in fact I think it out perform's my buddy brent's x-2 on the bottom
Crab
thanks darin...noswad!
Seattle
I have a nice 12/17 custom swirl that was made for the stock pump, worked awsome with the piped 650.
