Freestyle Prop help
Just finished a new build and need some help fine tuning the pump
701 with 185 psi
power factor pipe stock electrics
xfs
solas pump
solas liner
2012 sj prop
thrust trim
pump feels douy off the bottom and I don't know if its because of the pipe or prop what prop should I try ?
will be fitting jetmaniac 760 with epic and light weight flywheel
Unless you believe that the electrical problem is in the CDI itself, then this is a bad idea. The Epic is a great ignition but it is less forgiving of crappy wires, coils, etc.
JetManiac
Stoked
Vendor Account
orlando
I've run a similar set up with a total loss and a b pipe and a 9/15 hooker worked extremely well. These pumps also seem to work a lot better with a stubby pump cone.
Chris.
X2 many have had good results installing a shorter pump cone on their solas pumps.
Might have a small electrical problem as well I might fit the epic and see if that helps
X2 find your problem and install epic on an already good running setup.
I have a 9/15 and stubby cone on order should be here tomorrow as for electrical problem it was a burnt out wire but fixed it and installed the epic the pump feels very sluggish it's fine if im already moving at a good speed but if I turn to hit my set up wake and slow to much it takes a little bit for the motor to spin up.
Fingers crossed the new prop and cone helps the motor spin up plus my new motor should be ready in a couple days .
