Short answer, no it’s not worth it.The long blade is a big advantage for the fw skis, but is the extra $$ worth it to get a long and thin blade? What and how much of a difference does it make?
Please enlight a pump newbie
I’d argue differently. For the regular riders no. For the pros trying to double, well then you have different case. You need to have the HP to pull a long blade.Short answer, no it’s not worth it.
But again you have to have a need for it. Average joe a regular swirl will work.
I do feel there is some benefit to the thin blade from the weight taken out of the prop. But again if you’re just running a 701. Spend the money getting a prop that is pitched to the exact spec of what you need. The numbers on the props are not always (never) right.What about the thin blade option then?
Ill take it a step further and say buy the tools to measure the prop. Some of the stories ive seen about how off their prop was read like troll/meme fan-fic.I do feel there is some benefit to the thin blade from the weight taken out of the prop. But again if you’re just running a 701. Spend the money getting a prop that is pitched to the exact spec of what you need. The numbers on the props are not always (never) right.
%100000 correct. Ive done back to back testing and there is an extreme difference on a driveline thats tuned for it.I’d argue differently. For the regular riders no. For the pros trying to double, well then you have different case. You need to have the HP to pull a long blade.
