pulse or remote
Y
yamaslut
Guest
I tapped... when you say "better".. what do you mean??
tapping was better on my wallet
fuel pumps will deliver a higher, more constant and regulated pressure, I would assume.
Some carbs don't come w/ the pulse pump like Full Spectrums... you have to use a remote.
couchhater said:
is it better to run a romote fuel pump versus tapping case for second pulse line?
Mile9c1
X-H2O.com
Grand Rapids, MI
There is no difference in performance. I used a remote last year, because it allows more clearance between the carbs and the exhaust tube, when you run the fuel pump side of the carb(s) out.
Takeastand SJ
R.I.P. 8/9/2008
Washington
Remote fuel pumps can supply higher fuel pressure which helps for single carb set ups. For duals I'm not sure if it would give you an advantage.
