Custom/Hybrid Pump Compatibility
Hi Guys,
Farily new to the jet ski world. I recently picked up a 701 blaster (94). I am thinking about picking up a 95 wave raider for a parts ski. My question is does anyone already have a write up on drive line compatibility between skis? Are wave raider pumps and shafts compatible as well as other skis?
Myself
manic mechanic
Twin Lakes AR
If the Raider is 701 powered then the pump itself will be the same. Driveshaft length and impeller pitch would surely be different.
JetManiac
Stoked
Vendor Account
orlando
Raider 701 is same 144mm pump size, but driveshaft is different length. Pump stator is the same, wear ring is the same except you need to helicoil for the long pump bolts which need to be shortened.
Nozzles are different but we can swap you out and mod the driveshaft to blaster length for you.
