- michigan
1993 SXI Big Pin Motor. Just noticed a grinding sound in and out of water. Seems to be coming from the pump area. Inspected the pump and impeller and see no damage, or obvious looseness. I suspect the impeller shaft bearing at the pump, but wanted to get some input before a tear down.
Thank you
Thank you
