Make sure that sure that you slide the wear ring evenly over the impeller, as the impeller has a tight enough fit that just a fraction will cause it to not go down all the way around. Also if you are using mixed pump parts from various 144mm pumps, that you have any locating pins lined up properly as well. As stated above, put the pump together out of the ski and then slide it in as a whole unit.
Kurtis
