fishinrod
guerrilla steezin
- annapolis MD/greenville NC
Im just finishing up a winter rebuild and about to start putting the ski back together, my question was about shimming. The only shims were on the motor mounts. and since i cut 3 in off the hull and got some glass on the pump area and the height might be different, barely though. if there were no shims before is it necessary to add them now? can i just keep the same shims that were on the motor before even if everything including mid shaft came out?
thanks,
roddy
thanks,
roddy
