I think I have this one solved. I thought my pump bearings felt fine on my 'Blaster too, and the pump was the only thing that I didn't rebuild when I went through the entire rest of the machine. Once I had my pump out, I noticed that the driveshaft was moving (just a little bit, maybe 1/8" or so) back and forth in the pump for some reason. I decided to tear the pump apart and put in all new bearings and seals. I just got done rebuilding my pump with new Koyo bearings (DO NOT use cheap Chinese bearings or ebay Chinese copies of actual Koyo or SKF bearings) and new OEM Yamaha seals. It seems like the driveshaft isn't moving in the pump now like it was before. I'm going to wager and say that this solved the problem, but I'll have to wait and see until I can get it in the water in about 3 more months. I also put in new Boyesen reeds, hooked up dual cooling, I got a Factory B Pipe with a Mod chamber to replace my Riva Red pipe, and a new Impros Hooker 9/15 prop instead of the 10/16 that I have on there now. I'm hoping that it ought to have a little more low end grunt now.
