Pump sealing
Pa
On a superjet pump do you silicone the pump sections together? Stator, wear ring, and reduction nozzle. The manual says to use silicone but I see a lot of people use nothing
I use the Permatex Ultra Grey, it's supposed to have higher vibration resistance. Not so much to seal the sections, they won't leak without it, more so to displace the water to limit the white corrosion build up.
Never silicone the 3 sections together. It's unnecessary and is a bitch to get apart . The reason the krash don't have a seal is because the shoe bolts directly to the wear ring.
I've had them be a bitch with or without sealant especially at the stainless dowels, in my experience at least the sealant limits corrosion in salt water only boats, 99% of my riding.
