- Ontario, Canada
I posted this on a thread where ppl were asking if a q8 can flat water back flip with small power set ups so here it is stock SXR 800 motor (781cc) factory pipe wet pipe, stock carbs (38's) and 145 set back mag pump 9/16 skat prop. everything else was taken off an SXR to go into the 2011 carbon/kevlar hybrid EME Q8 hull. I also weigh 230lbs and am 6'3" total ski weight with full tank of gas 270lbs i
for those who think that you need a big motor to flat water backflip
Hope this gives hope to those with small wallets like myself
